Salta al contenuto principale
iPhone con schermo da 4" introdotto nel marzo 2016 con specifiche hardware simili a quelle dell'6s. Disponibile in Argento, Oro, Grigio siderale, Oro rosa con 16 o 64 GB. Modelli A1662 e A1723.
1046 Domande Visualizza tutte
New screen not working
Hi, I have replaced my cracked Iphone SE screen but working one with a new. I disconnected the battery, and followed the guide.
When I start the Iphone, It has no image. The screen is black, but with a little white light, but no image.
Change with another new screen, and the same. Put the old one, and gives me image.
HELP!!!
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
after every screen replacement, Try a hard reset. (home button, and power button for 20 seconds)
This is similar to a cache wipe on computers and will get rid of most basic software discrepancies.
check to see if you are just not getting a backlight. Hold a flashlight to the screens, and see if you get a sillhouette of a picture. if you do, you may have backlight issues on the screens. Make sure the solder joints at the top right of the LCD on the back is covered, and make sure they are secure
If something was internally damaged, then you would not be getting an image from the OEM screen.
Punteggio 0
1 Commento:
Thanks, Scott. I did try a hard reset, and the issue is that the backlight does work, but the image does not.
da
If the old screen works but the new screen doesn't then it sounds like you have some faulty screens, make sure your screen supplier has good reviews because I had a batch of bad screens then bought a screen from a different supplier and it worked so it proved the batch of screens I had was all faulty
Punteggio 0
1 Commento:
Thanks, Danny. The screen is from ifixit, but I'm sure it is possible it is defective.
da
Aggiungi la tua risposta
Nicolas Bonfante sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 111
