Stuck on 1-1-1970 after screen replacement
In replaced an iPhone 6 screen, but now have a problem I never seen before. The iPhone is stuck at 1-1-1970. Even after unplugging the battery, nothing I do is solving the problem.
What I tried:
Setting the date time to automatic
Connect to wifi
Connect with 4G
Connect to pc
Change date manually doesn't do anything: the date and time doesn't change at all
I call and send text messages (strange?). Everything with internet involved, obviously doesn't work.
Also, Bluetooth doesn't seem to work. Spinning wheel keeps on spinning.
Wifi gets connected, so works.
Any thoughts? Thank you!
Questa è una buona domanda?
9 Commenti
im assuming the phone itself currently has cellular service?
da Scott
Yes, it has. I'm able to receive phone calls
da Thomas N
have you tried running through the factory restore? if that doesnt fix it, you will be looking at a failing board component.
da Scott
Complete factory restore, not yet. But I have already restored all settings.
Should I try the full factory restore?
da Thomas N
Full factory restore as in restoring the iPhone via iTunes?
da Ben
Mostra altri 4 commenti
