Salta al contenuto principale
Model A1297 Unibody: Early 2009, Mid 2009, Mid 2010, Early 2011 & Late 2011
544 Domande Visualizza tutte
Greens instead of blacks. Temporary fixable, but not permanently
Hello,
My mum has unibody macbook pro 2009 17" (3.06)
It has an annoying problem - it displays greens instead black, and it can be fixed temporarily by pushing the middle of palmrest over the keyboard (there is a radiator)
I suppose that it is caused by faulty flex cable. Did anyone have similar problem?
Thanks for help in advance
Update (11/11/2017)
I replaced thermal grease. And happened something after reasembling the computer. I noticed that screen goes green when i push the bottom of the laptop around place shown on the photo
Questa è una buona domanda?
Punteggio 0
2 Commenti
External monitor works properly
da
Then your LVDS cable is damaged or the LCD its self.
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
SOLVED
I put silicone or rubber port covers inside.
Back cover was causing problems. Now it is properly isolated and doesn't touch the mainboard. Everything is fine now!
Punteggio 0
Risposta Più Utile
To try to determine if this a cable, battery or GPU issue, plug it into an external monitor and see if the same thing is occurring there.
Punteggio 1
2 Commenti:
External monitor works really well
da
Also check to see if your battery is swollen.
da
Aggiungi la tua risposta
Maciek Welk sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 60
