Salta al contenuto principale
7.9 inch display / Model A1454 / Available in black or white / Announced October 23rd, 2012 / 16, 32, or 64 GB capacity
Which is the best Double tape for Remplaced Screen?
Which is the best double tape to stick the ipad? Or the most advisable glue to stick it?
When mounting the ipad mini I notice that I do not hit correctly.
And what would be the best way to remove the excess tape that comes with the original screen?
Questa è una buona domanda?
Punteggio 1
1 Commento
Thank you, I appreciate your help
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Acetone works well to remove the old adhesive, then clean with IPA. As for the adhesives, the Tesa Tape sold here at iFixit is probably the strongest tape you will find but it is only sold in rolls. If you want pre-cut tape for the iPad, consider BowlerTech or TapeTemplates.
Immagine Custom cut rolls of Tesa 61395 double-sided tape for repair.
Prodotto
Tesa 61395 Tape
$5.99
Punteggio 3
1 Commento:
da
Personally, I use https://www.amazon.com/gp/product/B00OZG...
Sometimes the factory adhesive is a bit thick and doesn't set very well even with heating, it can also make the home button sit higher so it doesnt make contact.
If you apply about 80C heat to the existing tape it should soften it enough to help peel it back off.
Punteggio 2
1 Commento:
da
Aggiungi la tua risposta
Christian sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 12
Tutti i Tempi: 5,348
