Why isn't my brush roll moving?
My brush roll won't move because there is something stuck.
Questa è una buona domanda?
Open up your vacuum cleaner and check the belt. It likely has snapped or snagged and needs replacement.
ok, I ll try your recommendation, but still need the replacement that goes closer to the bus . The roller cover please. Would you help me?
the brush is ran by a belt. check to see if it has come off. you will have to remove the bottom but it is usually a phillips head screwdriver to do so.
Ultime 24 ore: 1
Ultimi 7 giorni: 7
Ultimi 30 giorni: 27
Tutti i Tempi: 784
1 Commento
I have taken the brush assembly apart and cleaned any buildup which was minimal. It will spin sporatically. Most of the time not.
da blackbear524
