Salta al contenuto principale
Lanciato il 25 settembre 2015. Modello A1688/A1633. Si ripara in modo simile alle generazioni precedenti, richiede cacciaviti e strumenti di apertura. Versioni GSM o CDMA /16, 32, 64, 128 GB / Oro rosa, Oro, Argento, Grigio siderale.
2532 Domande Visualizza tutte
iPhone 6s after screen replacement boots up then dies?
After replacing my faulty iphone screen with the correct screen, and checking all screws are correct and all cables were replaced exactly, I tried to power up my device.
What happened was that it powered to the boot logo for about 5-10 seconds and then completely went blank. Then I tried plugging in a cable to the wall - it made the noise. Then I thought I placed the lcd wrong so I re-checked the cabling etc. and then rebooted. Next, it just displayed the 'plug in charger - out of battery' logo. So I plugged it in. Then (every time I powered up my device it showed the same logo) it just died mid logo...
Then I read online that I may have to give it time to do something ( I'm confused by this) so ,having no other way to power it down, I disconnected the battery cable in the phone. Then I waited and powered on and it just repeated the out of charge logo situation over and over and (I kid you not) over again -- no sound of charging anymore (I changed cables as well).
Next I tried to connect to itunes and then it recognised (yay?) but told me to unlock the phone... but I had no way to actually unlock the phone..
Now the power button seemed to not affect the power down(?) so the only way I could reboot was unplugging the battery cable. So that's the only way to display logo once before it died. Even now, plugged into the computer, it doesn't power on or show any signs of being alive...
So then I read it may be caused due to battery but I am wondering can a faulty battery (or even dead) be recognised by itunes?
P.S My screen didn't die as it did show the logos (idk about backlights)
Questa è una buona domanda?
Punteggio 0
Commenti:
did you measure the battery voltage ?
did you try to change the charging cable ?
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
If it's making noises but nothing on the screen it's either.....
Not plugged in properly
Bad screen
Blown backlight / LCD driver circuit component.
If it's working but rebooting on the Apple logo you've possibly damaged the proximity sensor / front camera flex. Try unplugging the camera flex then plugging in the battery and trying again.
If there is no sign of life at all try unplugging the screen etc, then make sure the dock flex is connected to the board, and the battery is connected to the board. Then try plugging the phone, minus the screen into a pc. Make sure the mute switch isn't turned on. Look in iTunes and listen to the phone for any sounds. If you see the phone in iTunes it's fine, so try checking the screen etc.
If it's not showing up you need to check the battery cable / connector on the board / charge cable / dock connector / dock etc for damage, if all is good try another battery or test the battery for voltage across the two large pins.
Punteggio 1
Aggiungi la tua risposta
Te ForMe sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 54
