Salta al contenuto principale
Lanciato il 25 settembre 2015. Modello A1688/A1633. Si ripara in modo simile alle generazioni precedenti, richiede cacciaviti e strumenti di apertura. Versioni GSM o CDMA /16, 32, 64, 128 GB / Oro rosa, Oro, Argento, Grigio siderale.
2686 Domande Visualizza tutte
Spilled Beer on my iPhone 6 and now bottom of screen is unresponsive?
I was on a bus yesterday and beer had been dripping from the roof of the bottom deck onto my phone, I didn't notice until about 20 minutes had passed, I used my phone for about 30-40 minutes after that to see if i could get it to work but after that I turned it off and have now had it in rice overnight everything still works except the very bottom of the screen, should I leave it in the rice or get it fixed??
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta Più Utile
@nene098 you can take it out of the rice. Rice does not work. It does not fix corrosion nor will it prevent corrosion or short circuits.
I suggest you treat it just like any other water damaged iPhone. The very first thing you want to do is to not try to restart, sync or otherwise trying to use the phone. This may further damage your phone. The next thing to do is to clean it. Disassemble your phone using these guides . You must remove all EMI shields. If you do not remove those, you might as well not do anything. After you removed those, clean the whole board, connectors and all with +90% isopropyl alcohol. Follow this guide , and even so it was written for a 3G all the points are still pertinent to your phone. While you clean your board, check for any obvious damage, like burned or missing components etc. When it is properly cleaned, replace the battery. All these steps are to avoid delayed failure caused by corrosion. Best thing to do would be to clean it with an ultrasonic cleaner, but if you do not have access to one, this will at least help. Once all this is done, reassemble your phone and reevaluate. Until it is cleaned, everything will only be a guess. Even with all this, water damage has only a small chance to be fully repaired, but at least you can give it a try.
Punteggio 1
Beer will be the same as water. Water damage is always bad. You can always pay people to clean it top to bottom, but it will never fully fix it. They could clean it and it could work great for years, or even stop the next day or days after. You can always pay the price for “water treatment”, but there is never a guarantee.
Hope this helps!
Punteggio 0
Aggiungi la tua risposta
Courtney sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 16
Tutti i Tempi: 2,247
