Salta al contenuto principale
The 2014 version of the Galaxy Note 10.1", running a Exynos 5 processor and 3 Gb of ram. Released October 2013.
119 Domande Visualizza tutte
Battery Troubleshooting, says it's dead in ten minutes
I start using the notebook with a full charge, ten minutes later I get the low battery warning, it shows 14%. I turn the thing off and the battery icon shows 54% or some other random number with high percentage of charge. Even if I don't plug it in all overnight it shows 100% in the morning. What the heck is going on?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
I actually have this same model here at home for personal use and had a similar issue with charging. Googling the issue wasn't very helpful as there are tons of suggestions and possible problems and fixes.
I would start by holding the Home and power button down to enter a repair mode to see if that helps first.
Then check your charging port for debris to make sure it is not clogged up with lint, etc... using fine tweezers or toothpick (With it powered off) and be gentle as to not bend or damage the connectors (Magnification is helpful). Next, make sure your charger is working properly and cable is not damaged...then, the software, you can try restoring it back to factory defaults (You will lose data...back up first).
If none of these work, it could be a hardware issue or battery issue where you could need a charging port replaced or battery replaced.
Post back the steps you try and the results and any questions you may have. If uncertain on how to do something, ask first and someone here will be happy to help.
My issue was a bad battery :)
Punteggio 4
2 Commenti:
Wow, great info, thanks for that. Will try it all out , first I need to go get a new charging cord. I'll let you know how it all works out. Thanks again!
da
You're welcome, I hope one of them work out for you :)
da
Aggiungi la tua risposta
Irene Saumur sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 119
