What is the brake line diamter size going to rear brakes
2000 grand am gt need to replace brake line just cant find out the size
Questa è una buona domanda?
Use a digital caliper to measure the OD outside diameter. Take one end off, use the other small blades of the caliper to measure the ID inside diameter of the line. Go to an auto supply and requisition the length you need, always get it a little longer than you need, you can always cut off any excess after fitting in place,
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 762
