My retina screen has a white stain inside.
I cleaned my screen with a damp cloth, and this stain showed up. Why is that?
Questa è una buona domanda?
Liquid has leaked behind the screen and stained the backlight sheets. If you're lucky it might dry out, but in most cases it will not; so you are either stuck with it or you can replace the whole assembly
How come it leaked there? Was it damaged before which left a tiny gap or something?
Liquid will leak between the screen and rubber bezel if there is enough liquid
I think I'm lucky, it dried out.
Hi!
The same thing happened to me when I was cleaning off the residue of the peeling antiglare coating with various solvents (thank you, Apple)… Anyway, it is hot now so I hope it will dry on its own, but:
If I take off the display assembly and peel off part of the rubber bezel, how safe it is to ‘blow-dry’ the affected corner? Would it just cause more damage if I blow hot air over the sheets?
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 965
