Salta al contenuto principale
Modello fine 2011, A1278 / processore i5 2,4 GHz o i7 2,8 GHz
591 Domande Visualizza tutte
Help :( I'd like to replace 820-2936-B with a 820-3115-B. Issues?
I'd like to add an 820-3115 board to a 820-2936 machine. My board wasn't recognizing the battery so I send to for repair. Now it is completely toasted by a “fixing” company and now it won't even turn on. Anyway, what problems will encounter to replace old 2936-b with new 820-3115? Please someone? I need to buy from eBay and I don't won't to waste my money for a board that won't work. Also I need my machine for university assigments and I'm delaying things too much. Please help! :(
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
The LCD cable won't fit in the LCD connector on the 820-3115; they use a different silver connector, which is used in the later models. In theory you could replace the cable with a 2012 cable, but it would be a lot more hassle than buying a 2011 board
Punteggio 4
3 Commenti:
Any other than that? Like proscessing power or similar stuff. I saw a guy trimming the edges.
da
No, that is the main difference as far as I'm aware. Pretty sure you can force the cable into the connector, but it is definitely not recommended
da
That is not correct. The 3115 is not a retina! It fits with your display. As my 3115chasis with a 2936 board.
da
Aggiungi la tua risposta
Ledian sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 378
