iPhone Replaced Battery now sleep/wake button and video mic won’t work
Recently replaced my iPhone 6 battery. Now the sleep/wake button won’t work as well as faint-scratchy/no sound recorded on videos.
Questa è una buona domanda?
Ok, I should've just posted my answer earlier. So you've damaged some stuff while doing your repair. The power button, which is connected to the volume/mute, which you'll have to remove the battery and the logic board. It's a pretty big repair. Youve also likely damaged the front camera flex assembly. Not that big of a job. I mean you should check that and make sure you properly seated the connections. But likely you'll have to order new a new one
Sostituzione gruppo cavo pulsante di accensione iPhone 6
Sostituzione del cavo della fotocamera anteriore e del sensore nell'iPhone 6
Prodotto
$19.99
Prodotto
$9.99
Guida
Difficoltà:
Difficile
1 - 2 hours
Guida
Difficoltà:
Moderato
30 minutes - 1 hour
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 211
2 Commenti
Does you volume/mute switch work?
da iMedic
Yes it works.
da eric collins
