Salta al contenuto principale
Unveiled at the 2000 North American International Auto Show on January 10, 2000, the redesigned 2001 Dodge Caravan and 2001 Chrysler Town & Country were released for sale in August 2000.
179 Domande Visualizza tutte
Tail Lights don't turn on with headlights, signal and brake works.
Hello,
I've recently come across a problem with my 05 Grand Caravan SXT, where when I turn the headlights on, the Taillights don't work, but when using the brake light and signal lights, it works perfectly fine. Help?
NOTE: The signal, brake, and running light all use the same bulb.
Hope to get an answer soon, I really don't want to be pulled over...
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta Più Utile
@vinylcake yes they use the same bulbs but different filaments. So, I suggest you check the bulbs and fuse, after that check the condition of the connector making sure there is no corrosion. Those taillight assemblies have a tendency of leaking and corroding the bulb sockets. the
Punteggio 1
5 Commenti:
Both of the lights are out though, and I forgot to mention, they're LEDs.
I Checked the fuse for the lights, and they're still good which makes sense since they're still receiving power.
da
@vinylcake Stock or aftermarket?
da
Aftermarket, we have a load resistor kit on it, I checked all the wiring for it and it all seems to be fine.
da
You've checked the resistor etc. to make sure you still have power to the LED's?
da
Yes,
Also, if it didn't, the signals would start to hyperflash again.
da
TaI late lights don't go on at all, but everything else is good.
Punteggio 0
Aggiungi la tua risposta
Scott sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 6
Tutti i Tempi: 7,564
