trailer running lights not working at plug on truck
which fuse do i check?
Questa è una buona domanda?
Daleo Kelso this will only work if your truck has the trailer towing package. If it has been wired aftermarket, you'll have to dig a bit for it. For the truck equipped with the package:
Fuse F31 will be for the parking lights on the trailer connector and Fuse F58 is for the trailer connector backup lights.
Check #67 under the hood behind radiator. There is a fuse box there. I had same problem. It's a 20 amp blue 1cmx1cm square style with clear window at top. A simple continuity test will tell if it's bad.
trailer is working good now.
Look under the lid of the fuse box. Should tell you.
Ultime 24 Ore: 22
Ultimi 7 Giorni: 111
Ultimi 30 Giorni: 412
Tutti i Tempi: 38,303
1 Commento
# F 150 which fuse should I check when my trailer light not working
da Zane Walker Walker
