Salta al contenuto principale
Seconda generazione di iPhone. Modello A1241/8 o 16 GB di memoria/plastica posteriore bianca o nera. La riparazione è più semplice rispetto al primo iPhone. Richiede l'uso di cacciaviti e strumenti di leva e distacco con ventose.
1158 Domande Visualizza tutte
Domanda Chiusa
I can't touch the spacebar or the reply button on text messaging?
My iphone 3G reply button when text messaging does not work when the phone is flipped up in the normal position (vertically). I can't press the reply button or the spacebar or the symbol and return button. It seems that that space on the bottom of the phone isn't working.. but only when typing in the vertical position. All typing functions work when the phone is flipped horizontally. But, I can't type when its in the upright position. It is very annoying because it just randomly stopped working and I can't make any changes to the setting because the phone doesn't let you flip to a horizontal screen when typing in the settings window. Someone PLEASE help me fix this! All other touch functions work!
P.S The power button/hold button is broken on my phone so I do not have the ability to turn the phone off... any other suggestions?!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
3 Risposte
Soluzione Prescelta
Sounds like a bad app affecting your accelerometer- the horizontal/vertical alignment. Usually caused by overload of gaming app that needs tilt to steer. Remove your latest downloads one by one until the problem is gone if it's a jailbroken phone ( so you don't lose the jb) similar idea for normal phone or do restore in iTunes/update apps (maybe the dev team know ofvthe problem and hAve written the fix)
let us know how you get on
Punteggio 3
i've done everything..restore and jailbreak again..but it wont works.
Punteggio 0
4 Commenti:
try update network settings?
da
Reset network setting or update?
da
settings/general/reset/reset network settings. worked for me several times. sorry I put update..
da
Ive done so many time. But it wont work...
da
omg so is mine. i am getting ticked off here please help!
Punteggio 0
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 12,714
