Reboots whenever plugged in.
Guys I need help. My s7 edge reboots itself whenever plugged in. Same happens with different adapters and cables. The battery percentage is all over the place and it isn't decreasing.
The false percentage problem started to appear after I tested a third party battery with my s7 (note: the battery is working fine). Is it possible that the battery shortcirculted my motherboard?
The rebooting problem started after I wiped the cache on my device. (I'm restoring my system not sure would that helps. I hope this is just a software issue as I did use a custom recovery to do that.)
Questa è una buona domanda?
You are in a boot loop
da [deleted]
