Power supply for iMac retina late 2014
Which power supply should I buy ? Upper one or lower one ?
I linked below.
Questa è una buona domanda?
I linked below.
Hello,
You only posted one link... This part should be good as long and you correctly match the EMC#. You can put your serial in Everymac ultimate lookup to check you current models EMC#. Opening it up and replacing the PSU is the hard part.
BTW don't forget the Adhesive strips.
[prodotto collegato mancante o disabilitato: IF174-005]
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 790
2 Commenti
As far as I can see, those are the same part. Perhaps you accidentally put the same link twice?
da Rachel Acosta
Are you sure you need to replace the power supply? Double check your cord is good and review the diagnostic LED's what are they telling you.
da Dan
