Why is my printer skipping lines of text?
Hi,
I have an Epson XP 330. I have been trying to print a paper and it keeps skipping lines of text. I have done a nozzle check, cleaned the printhead, and also done an alignment SEVERAL times. Is there something else I can try? I feel like I am wasting ink and paper doing the alignment over and over, and I don't even know if I am doing it correctly. It started to skip less lines after the first alignment, but it's still not working and hasn't improved after the other alignments. I am a college student so my printer is essential... HELP!
Questa è una buona domanda?
6 Commenti
I was first suspecting that printing on cardstock was causing the feeding to not be able to feed plain paper through the paper feed correctly. Is there a way to fix the paper feeder so that it can feed paper without skipping lines?
da bonniej609
Wow! Problem fixed! Thanks you! It’s been like that for months!
da ggcoralysp
I just went back to an HP printer with expensive ink. Never had problems with HP!
da H Frederick
My Epson wf 2750 prints the lines but won’t print the words or numbers
what can I do
da bcappsmidwife
Having the same issue. Doesn't matter graphical or text, evenly spaced blank lines occur along the page. However, the issue only occurs when printing in STANDARD quality mode. When I change the quality to HIGH, the lines disappear..... very confusing. Could this be a driver issue?
da Vincent Sojka
Mostra 1 altro commento
