Salta al contenuto principale
Rilasciato il 16 settembre 2016. Modelli 1660, 1774 e A1785. Disponibile come GSM o CDMA / 32, 128 o 256 GB / Rose gold, gold, silver, black e jet black.
1364 Domande Visualizza tutte
Charging port replacement stuck on apple logo
So I just replaced a customers charging port on their iphone 7 plus. Now when I plug the phone into the charger the phone starts to power up but it is stuck on the apple logo. A soft reset does not fix the issue, please help.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Small parts have a reputation for low quality. You may have simply received a bad replacement port. Depending on what the issue was with the original port, you could always re-install it to see if the problem is still there or not. If the problem persists, then your issue could be logic board related.
Punteggio 1
I am sure you short any component in charging way or may be u2 ic (usb ic) short
Punteggio 0
Aggiungi la tua risposta
cellphonebuyer1 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 2,447
