installing memory in 2133
when I install new memory 4 gb 2x2 imac does not work, when I put the original 1gb back it works.
any suggestions?
Questa è una buona domanda?
any suggestions?
have you confirmed you have the correct type of RAM for your model iMac?
the Mid 2007 20" 2.0GHz/2.4GHz iMac uses PC2-5300 (667MHz) DDR2 SO-DIMM memory
the Early 2008 20" 2.4GHz/2.66GHz iMac uses PC2-6400 (800 MHz) DDR2 SO-DIMM memory
Make sure you're inserting it correctly too.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 2,134
