Tv has no sound
Turned tv on, everything seems to work but lost sound. Tv only 14months old.
Questa è una buona domanda?
Hi, There are some most problem such as sound . Beside from the internal errors, check some most common fixes you can check for. ''
Check out the guide for the most common TV problems and fixes at- '''How to check and fix the most Common TV Problems'''?
Check whether you have connected the input cords correctly. In some TV, you can find the labeled input cords at the back of the TV.
@scottspeed you first ant to make sure that all of your settings are properly adjusted and you do not have a mute anywhere. Then you wan to test all different inputs to see if they are all the same (HDMI Composite etc.). If you use a set top box to connect your cable reset that as well. If all of those check out, connect an external speaker or sound bar and see if that works. If still no luck, you will have to pen your TV and check the main board, speakers etc. Post some images of your boards, wiring etc. with your question so we can see what you see,. For that use this guide
Of course, before you do any of this you want to check to see if this is covered under any kind of warranty. If so then use that to get it fixed.
Audio wasnt workin on pc so tried checking if it was the PC after a bit of troubleshooting, i checked the tv
Played somethin on amazon, sound was still not working, tried turning it off and on again, a few times
Until…
fix(for me)
Just turned it off and on again (at the plug socket), apparently there was an update, that seemed to fix it
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 9
Tutti i Tempi: 18,003
3 Commenti
Checked everything as much as i can without opening back just yet.
Have sound in audio jack but no sound from tv speakers
da Dwight Scott
My tv has sound but wont stay on unless u push the star button on remote
da roseandjohn1234
I have a JVC 42 inch and the sound is went out pictures showing perfect but there’s no sound
da mdonaldson482
