What is this components which leaked?
Hello, my Macbook Air does'nt start, it looks dead, the battery is charging, I tried all the tricks I found in the forum, SMC reset … all of them.
I opened it and tried also to start with the pads, and also with the start button and discovered that the fan started to turn and stopped. Each time I push the start button the fan turns 2 seconds and stops. All that with the battery connected, or the battery disconnected and with the magsafe
I found that a component leaked a bit, the leak looks like brown jam.
I join a picture, the component is highlited in green (I took the picture from the site, so you won't see the leak).
I suppose that the motherboard is to be changed, I don't have the skills to change this component.
I'd like your advice.
Thanks for your help.
Update (09/21/2017)
Hello Minho, thanks for your answer.
The logic board number is : 820-3023-A
Here is a picture where we can see the leak (and some dust) :
and another where we can see the part number of the component which is the same as the other 5 components on the side.
Do you have an idea of the price of the soldering ?
Thanks very much for your help.
Questa è una buona domanda?
