How to use a SD card
It won’t download anything on one I just put in
Questa è una buona domanda?
Worked on some BLU Phones but not this model in particular.
After you put in the card, go to settings > storage and make sure the SD Card is working. If it isn't then you will most likely need to format it in order to read. If it doesn't work after that, then you are either putting too high of an SD Card or you need to use a different brand (Very little chance)
Once you know it's reading properly, under Storage, you should be able to make the SD card the default write disk. Then restart the phone.
Hope this helps.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 291
