Salta al contenuto principale
La versione 2016 dello smartphone economico Samsung Galaxy A3 (numero di modello: A310F).
Why does my touch screen don't work?
So I was checking my bag, when I pulled out my clothes from my bag, my phone fell, but I dropped it when my bag was low near the ground, I used the phone in a bus, it worked, but when I was at home, and I couldn't press anything, when I click it, it doesn't work, the back and the other button works though. If I try to restart or power off, it doesn't work because I need to touch either the restart or power off, holding the power button for 10 seconds it didn't get powered off, can someone help me?
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
3 Risposte
Soluzione prescelta
To power it off, hold the power button and volume down until the phone restarts. Power it back on and let me know if touch starts working again. Hope that helps!
Punteggio 4
9 Commenti:
It fixed :3, I stopped charging for a few days, and it shutted down, I opened it then it worked again!
da
@vygantasfix Well that is not good! I have voted to get your comment switched to a question so you can get your device fixed! (hopefully) I can't provide help for you very well, but if that vote passes some other community members might be able to help you. Good luck!
da
Thank you Reed. To power it off, hold the power button and volume down until the phone restarts. It worked.
da
@negreadd No problem! I'm glad it helped, that's what I'm here for!
da
I got exactly the same problem. I managed to restart it, but the touch is still not working. Does that mean I have to replace the touchscreen? Need help
da
Mostra 4 altri commenti
holding the power button down and pressing volume down just takes a screenshot, you cant take off the phone cover or restart the phone without touching it, please i need help, i cant get another phone, someone tell me a solution
Punteggio 0
My phone toch stops working i tried to reset through power and volume button it does not work and os downloading starts and stuck
Punteggio 0
1 Commento:
I had the same issue with my tab. the thing was I did not charge it for a long period so battery was empty and of course the tab turned off. I charged it and the touch screen was not responding...
my solution: I removed carrefully the back cover, and I disconnected the battery and waited 10 min. then I reconnected the battery to the motherboard and turned on the tab to check that it was working fine again, and of course putted back the back cover.
that was my solution, you may give it a try if your touch screen stopped to respond... but if your phone feld, maybe something broked...
good luck.
da
Aggiungi la tua risposta
Sentai Genji sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 1
Ultimi 30 giorni: 15
Tutti i Tempi: 15,434
