Salta al contenuto principale
Introdotto il 19 settembre 2014, questo iPhone con schermo da 4,7" è la versione più piccola dell'iPhone 6 Plus. Identificato dai numeri modello A1549, A1586, and A1589.
4994 Domande Visualizza tutte
Changing my iPhone's motherboard
I've been using this iphone for quite a long time.Then it started too make problems.I brought it to a phone shop and they said i got to change my iphone's motherboard.What will happen if i change it?I really need help
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
2 Risposte
Risposta Più Utile
Is your phone turning on?
If yes, do a backup of your data via iTunes or other backup software so you can restore it to the new motherboard
If no, you will lose all your data, this is the worst it can happen
The motherboard is the most important component in your iPhone so the most expensive
Punteggio 1
1 Commento:
Not now :( @soros So,if i change my motherboard all my data including my icloud will be lost?Its like a new iphone isn't?
da
It is rare that you come by a motherboard that "IS NOT" repairable. There are several Iphones I have received that the customer was told this (even though it's possible).
First, you should explain your issues in as much detail as possible to help experienced techs troubleshoot your problems.
Second, to replace your Logic Board, is replacing your phone (It is your phone). If it comes to that, you are better served finding a good deal on another phone and replace that way, then you could sell yours to offset the price.
Here on IFIXIT, you can find several experienced techs that can do a repair to most anything that offer mail in services and even no charge in some cases where it is not repairable. Of course you would probably prefer a local shop if available and you have done your homework to make sure they are reputable and good at what they do... but you are here now after going to a shop which tells me they are good and correct, it is not repairable...or they are not.
Please update your question to include all of your symptoms and history of the phone.
Best of luck!
Punteggio 1
Aggiungi la tua risposta
Hazim Izz sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 2,727
