It may possibly be that the connector to the digitizer was loosened by the contact or it could be that you damaged the digitizer with the contact. I would probably take it to a place for replacement or to check the connection or you can tear it apart yourself. I personally would attempt to do a tear down on it and check the connection first it will save you some money if it is just the connection. But sounds like it is a bad digitizer. It is replaceable you will just need to do some research on finding the part for the replacement.
Hope this helps.... Samsung j LCD SCREEN REPLACEMENT
Votato
Annulla
Punteggio
0
