Salta al contenuto principale
Also known as EOS 600D and released in March 2011, this camera can be identified by its SKU (SKU:5169BO32). This camera is a Canon Digital SLR with 18 megapixels.
52 Domande Visualizza tutte
I have a totally stripped screw on the body that won't come out
Trying to self-repair my busted T3i SD card port but one of the screws that is right under the battery door of the camera is completely stripped so I can't get inside of the camera. Its deep in the hole so I can't use any sort of dremel, plus the rubber band/super glue trick was not successful. The screw is very small and the strip has become a complete circle. Any help would appreciated! Thanks!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Hi!
You could try using a drill with a very fine tip. Just drill into the screw until the head becomes separate from the rest; then applying some force, separate the two parts.
Punteggio 3
Aggiungi la tua risposta
Sahil Kumar sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 11
Tutti i Tempi: 850
