Burned components after water damage
I got water damaged(light water spill inside a backpack, near ABXY keys) 3DS XL for repair or to sell as parts. Ofc I want to do the former.
It does not turn on, nor charge, and after visual inspection i found 2 obliviously fried components:
- Charging IC (CKP, which is apparently Texas Instruments bq24072)
- Element DA4 near Wi-Fi card, marked D60(still unknown what it is, probably some LDO)
Picture of the place(metal sheild that should be under Wi-Fi board is removed):
Both fuses are not blown by the way.
So questions are:
- What is element DA4 and where can i get one aside from other 3DS?
- How to diagnose further to make sure i won't burn these components or anything else right after replacement?
- Is nintendo boards have elements glued to? I cant lift anything from board using hot air gun.
Questa è una buona domanda?
5 Commenti
@refectio @mayer @oldturkey03 Do you have any ideas, chaps?
da Alex Niculescu
The BQ24072 should be easy to source (http://ca.mouser.com/Texas-Instruments/S...). As for the DA4, it would help if the OP posted a picture so we could see what it is (or was ;>)
da Minho
If the label was intact, i wouldn't ask. I guess that this element is voltage stabilizer(5 pin smd), but i can't find needed rplacement without label, nor know what it is powering(all pins trace to inner pcb layer).
da Nuck-TH
What is the marking on DA3? Chances are they are identical or complimentary. Let me know so I can look them up. Tag me with my username (@refectio) so I get notified.
da Minho
@refectio DA3 is labeled D60, but i doubt that they're identical(what could need so much power in 3ds to have 2 same stabilizers?)
da Nuck-TH
