Why does the power cut off as soon as I turn on the unit
Power issue with Sony Radio CD player and cassette player CFD-S05
unit is plugged in and I have a second unit that works with the power cord.
Questa è una buona domanda?
Please check whether your symptom matches The Sony CFD-S05 unit will not power up . I added a detailed answer how I fixed the device there.
I have The Sony CFD-SO5 and so how did you go from switched to unswitched ? Did you have to tear the unit apart ? How do you bypass the On/Off button ?
I did take the unit apart. @oldturkey03 posted a link to the Service Manual. It explains how to take the unit apart. In my unit, the problem was *not* with the power switch, so bypassing either that button or the electronic switch controlled by it would have made everything worse. The actual problem is a short circuit on the main board. You have to fix that. The unit performs a kind of "self-test" every time you try to turn it on, and automatically turns off again if there is a short circuit.
Edward Walker you need to take a look at the power supply. Most likely a capacitor or transformer issue. Disassemble your unit CFD-S05 Disassembly and post some images of the power board so we can see what you see. Here is the guide for that Aggiungere immagini ad una domanda
Ultime 24 Ore: 2
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 31
Tutti i Tempi: 4,210
1 Commento
Great, i changed the capacitor and ifixit !
da Michel Beaulieu
