From JBL.com
It is possible to replace the ear pads, but there are details to consider.
On Elite 700: The ear pads are held in place by a plastic plate with claws, and some of the claws will most likely break off when you remove the pad.
You do this by grabbing under the edge where the fabric ends, then pulling hard outward.
The claws will eventually let go, and some of them will break off, rattling inside the ear pod.
The only way to get them out is to unscrew the speaker plate, lift it up, and shake out the broken-off claws.
The new pads are simply centered over the speaker plate, and the claws pressed into the holes with a firm pressure.
On Everest 700: The ear pads are glued into position with double-adhesive tape.
Pull the old pads off with a forceful, steady pull, until the glue lets go.
Remove the protective layer on the new pads, and carefully position them correctly before pressing home all the way around the edge.
Votato
Annulla
Punteggio
4
Annulla
Scorri questo thread per trovare il posto appropriato per questo commento. Quindi, fai clic su "Allega commento a questo post" per spostarlo.
1 Commento
Im not here to answer i had this headphons for a year oe moee and not just did the leather was $@$* it also tore apart and i can see the freaking sponfe that they put inside
da alon.faigel
