How do I fix the brake lights. left side
How do I change the brake light on the left side of my truck
Questa è una buona domanda?
If switching bulb to other side verifies bulb is Ok,
Or simply using test leads to truck battery -
Then you'll more than likely have fuse problem,
This panel might be in engine bay, if not inside cab.
The user manual will have location for fuse.
Note:
By Chance , was a trailer used recently?
I've seen this being the case many times,
The lead on trailer, or socket is damaged.
Blows the fuse.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 38
I don't know how to even take the light covering off
da Joyce Makua
