Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Quinta generazione dello smartphone android al top di gamma Samsung, rilascaito l'11 aprile 2014. I miglioramenti rispetto alla serie successiva comprendono lo scanner impronte digitali, la fotocamera aggiornata, lo schermo più grande e la resistenza all'acqua. Disponibile in quattro colori differenti: nero, blu, bianco e oro.
634 Domande Visualizza tutte
How do I access the letters instead of numbers on the dialup pad
can`t find anything on the dialup pad to change numbers to letters
Questa è una buona domanda?
Punteggio 14
Commenti:
That's the way it will look. For instance, when someone's phone number is 1-800-CALL-NOW, their number is actually 1-800-222-2-555-555-66-666-9. That's how it looks. The letters are just so you can spell things in a phone number, but it's still just a number. To the dialer letters are just numbers.
da
No answer …same question..how the !&&* do I access the letters and symbols on my Samsung Galaxy 7 phone key pad?
da
I won't my old letter back I can read it
da
How can I do this for a password with some numbers and some letters. It does not know what I am saying because it is not a word..
da
I have this problem, Human resources in my country lets me speak the first 2 passcodes they need to let me talk to someone then I'm asked to input a third which ends in a letter, (this is new) there is no way I have found to input anything but numerals, we are not talking about the corresponding letters assigned to each numeral on the keypad so we can work out what "1-800-CALL-NOW" is but to actually input a letter.
da
Mostra altri 8 commenti
Aggiungi un commento
8 Risposte
That is what you dialer should look like. To use the letters under the numbers, enter the number to the count of the letter you want to use. For instance, if I wanted to enter the letter B, I press two twice. If I wanted to enter O, I press 6 three times. Understand?
Hope this helps!
Punteggio 3
Commenti:
thanks for your advice George. I pressed 2 twice, but all that came up was
2 twos. same with o, up came 3 sixes. What do you think?
da
Sounds like tom wants his password to be a word instead of a number. Like using the letters on a standard dial up phone to spell it out. For example WORD would be 9673
da
The answer given by George A. is totally wrong. The answer given by mayer is the correct answer.
da
Some carriers require a letter in the passcode to unlock the phone. I was FORCED to use a letter and now my phone is bricked because I can't type a letter after a system update.
da
Its not helping cause have tried so many times if l press 2 twice it gives me 22 while l need alphabet
Punteggio 2
Commenti:
Its doing my head in
da
I am doing all kinds to find an answer. I am sorry to say the answer is not on the net. Try your service provider. Just an idea. Good luck!
Punteggio 0
How do I get the letters on my phone dial pad ?
Punteggio 0
Commenti:
da
So give me right way
da
Hi just discovered on my phone. Hold down the required key for a few moments and this works.
da
try pressing the * key a few times
Punteggio 0
Commenti:
Done thataswell
da
I have the same issue, i.e, pressing the 2 key results in an A, WHEN I WANTED THE NUMERAL 2 TO APPEAR. It puzzles me that no one has correctly answered this basic question. Has anyone tried to contact the cell phone maker of their cell phone? Although, I would think all cell phones should function identically. Will someone correctly provide a solution.
da
On my phone how do I change between numbers and letters I have an IPhone and I am trying to put in a code for chromcast
da
I went into my actual ‘pair a new device’ part of my phone and it came up with the complete keyboard!
Punteggio 0
How to enter the letter s on a cell phone
Punteggio 0
Down load the app textnow its got both with a click
Punteggio 0
Aggiungi la tua risposta
tom moffat sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 63
Ultimi 7 Giorni: 731
Ultimi 30 Giorni: 3,339
Tutti i Tempi: 107,749
