Salta al contenuto principale
Quinta generazione dell'iPhone. La riparazione di questo dispositivo è semplice e richiede cacciaviti, strumenti di apertura e pazienza. Nero o bianco, GSM/CDMA / 16, 32, o 64 GB.
2191 Domande Visualizza tutte
iPhone 4s broken battery connector repair
My iPhone 4s battery connector got detached from the logoic board, after soldering it back iPhone isn't charging and restart every 3-4 minutes like screen goes gray black and apple logo comes.
I have one more battery tested with that but there is no difference.
Battery was 57% and 2 hours later 40% while connected to the charge.
Edit:
Have a look at the detached battery connector. Please suggest can it be repaired or not.
Questa è una buona domanda?
Punteggio 3
Aggiungi un commento
3 Risposte
Risposta Più Utile
It can be repaired I believe that
Punteggio 1
Your battery connector is not properly installed one of those pins is not getting good contact that's why the iPhone is acting up good luck I have soldering those tiny pins I had to solder and resolder my battery connector 4 times to get it working again GOOD LUCK
Punteggio 0
15 Commenti:
Hi Mario thanks buddy for the suggestion but i checked all the connector using a multimeter they were connected properly though.
da
So there continuity to each pin?
Did you accidently remove any of the tiny resistors by the connector?
da
I ran into the problem your having and it's stressful and a pain and I noticed that 1 or 2 things this is assuming the charger and cable are working correctly was 1. Replacing battery and 2. Resolder the plug once again
da
I never felt that there is any resistor near the connector.
da
I resoldered 3 times and everytime checked i got the same issue.
da
Mostra altri 10 commenti
There should be ics by the connector ignore the jumpers on the image because I can't remember if this was the 4 or the 4s but you should have components next to the connector
Punteggio 0
2 Commenti:
I just stopped looking for the answer I have tried a lot also i got few issues like i got it repaired several times from a shop and i found out there that there are no components near the battery connector i think those jumper got detached.
or might be I have lost all those resisters.
da
You have provided for the 4S
da
Aggiungi la tua risposta
Sabhay Sardana sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 9
Tutti i Tempi: 2,758
