My Left High Beam Doesn't Work
I recently purchased my 2002 Ford Explorer Limited and my left high beam will not turn on. So I purchased new bulbs and the left high beam still will not turn on. Then I checked the blue 20amp Bussman female maxi fuse at F1 19 via the see thru plastic cap and the fuse is fine. So I pulled the fuse, checked the 2 flat contact points in the fuse box with my circuit tester with the engine on and grounded to my battery. Only one contact point made my tester light up. How do I fix this problem and did I test it correctly?
Questa è una buona domanda?
