Screen door won't close completely without my lifting it into place.
Screen door won't close completely without my lifting the closing pieces into place. Can this be fixed?
Questa è una buona domanda?
This is very common. Usually the door drops. First tighten the upper hinges and see if that pulls it up. If not you may have to put a shim on the lower hinge to push it out. When doing that I would start with an 1/8" shim and try it with the screws out and see if it is enough. If not add another one until it gets aligned.
Ultime 24 Ore: 3
Ultimi 7 Giorni: 25
Ultimi 30 Giorni: 131
Tutti i Tempi: 3,055
1 Commento
Thanks ever so much. So nice to have the screen door fixed!
da Jane
