Is there supposed to be water in the bottom of agitator
Is there supposed to be water in the bottom of my washer drum after it has been removed and the washer has been drained? Ie ballasts or something?
Update (08/16/2017)
No sorry I should have been more specific. I removed the drum from the machine so that I could change the bearing seals. When we pulled the drum out of the washer there was still quite a bit of water inside of the plastic base of the drum. It doesn't leak out and we can't get it out. Like it is supposed to be contained in there
Questa è una buona domanda?
7 Commenti
Same problem, BUT the water is leaking on to the floor.
da shelley.belsky
If it’s leaking, you’ll have to visually determine where the leak is coming from since I’m not there to see it. @shelley.belsky
da LadyTech
I wonder if maybe it is supposed to be in there to keep the drum from floating up too high when the inner portion is filled with water? Like weighing down a pool noodle.
da Katie Courter
I get what OP is saying, and I don't think any of the answers really covered it. Water is inside the sealed base of the inner drum. I have the same problem on mine.
da Grant Engfer
Same problem
da Freddie Garrett
Mostra altri 2 commenti
