Salta al contenuto principale
The HTC One (codenamed M7) is HTC's 2013 flagship smartphone. It features a seamlessly designed unibody aluminum frame, large dual front-facing speakers, and a 4.7-inch 1080p display.
149 Domande Visualizza tutte
Why does vibrator motor run nonstop when the battery is plugged in?
replaced battery. when I reconnect the battery to the socket on the motherboard the vibrator motor runs like a "motorboat" I cannot see any mis-connection to cause this. phone was operating normally before battery swap.
Questa è una buona domanda?
Punteggio 0
2 Commenti
If you reinstall your original battery, does the issue persist?
I also would recommend doing factory reset with the new battery installed.
da
When this works, please tell me, thank you!
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
I had it once when some greyish material used for insulation flaked and a small piece got stuck inside a connector. It bridged two pins and caused a short - constant vibration.
Once I found and removed it, the vibrating stopped.
Punteggio 3
I have seen this with HTC and it was a failed motherboard, would not turn on it had not been opened phone would vibrate on battery connect but battery was fine in other phone, if you need help https://fb.com/groups/aidanmacgregor/?ft...
Punteggio 2
1 Commento:
thanks for considering my problem
da
Aggiungi la tua risposta
Robert Rinehart sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 265
