Salta al contenuto principale
Lanciato il 25 settembre 2015. Modello A1687/A1634. Si ripara in modo simile alle generazioni precedenti, richiede cacciaviti e strumenti di apertura. Versioni GSM o CDMA /16, 64, 128 GB / Oro rosa, Oro, Argento, Grigio siderale.
1041 Domande Visualizza tutte
New Battery: Phone Shuts off When Idle/Blank Screen
I have done hundreds of these installs and have never seen this issue. I can watch movies, surf the web, do pretty much anything that keeps the phone "awake." However, anytime I let the screen go blank/timeout/idle (whichever you call it), it turns itself off after a few minutes. I installed the battery last night and was able to surf reddit for a few hours, then upon letting the phone go to sleep it turned itself off after a few minutes. This is the repetitive series of events that occur each time. I have tried soft and hard resets.
Whats even stranger is that I cannot turn the phone back on unless I plug it into the wall. I am not able to turn the phone on using the power button. The battery is fully charges as I am able to use it unplugged as long as I don't let the phone go to "sleep."
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
You should try a full DFU Restore to eliminate any possible software/iOS corruptions issue. If that doesn't work, then you will need to start isolating the major subcomponents (screen, cameras, sensors buttons etc) one at a time until you either find the culprit or isolate it down to the logic board.
If you are uncomfortable doing these steps, consider finding a repair shop to do the troubleshooting. A shop that also does micro-soldering can go deeper if the problem is not modular in nature.
Punteggio 1
2 Commenti:
I did a DFU Restore and the same issue. How would I isolate the screen? Do you mean disconnecting and rebooting to see what happens?
da
Yeah, just disconnect one item at a time to see if it solves your problem. Disconnecting the screen requires that you use a tool like 3uTools to see if the phone is on and if/when it reboots. You should also remove the PIN so the screen isn't locked.
da
I changed my iphone 6 battery by myself with an aftermarket one and it worked normally for 1 week then it developed the same issues as you described. I complained and got another battery from the seller. With the battery replacement , the phone has been back to normal again ever since.
Punteggio 0
Aggiungi la tua risposta
Christopher Nowak sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,539
