Salta al contenuto principale
Introdotto il 19 settembre 2014, questo iPhone con schermo da 4,7" è la versione più piccola dell'iPhone 6 Plus. Identificato dai numeri modello A1549, A1586, and A1589.
4994 Domande Visualizza tutte
My iPhone won't turn on after a battery replacement.
I replaced my battery because my phone kept randomly dying and the charge wouldn't last long. After prying the battery up from the left side by my volume buttons, I connected the new battery sensor and re-connected my LCD sensors. I then turned the phone on just to make sure that it was working properly. The screen turned on so I turned it back off and place the metal covers or brackets over my LCD sensors and over the battery sensor. I put the screws by the charging port back in and when I tried to turn it on the screen remained black. Then when I tried turning it on by applying pressure to the power button or plugging it into power, the sensors by my front camera and earpiece seemed to heat up. They remained warm until it was unplugged or pressure wasn't applied to the power button. I think took apart the pieces by my front camera and earpiece and nothing seem to be blatantly wrong with them. iTunes still recognizes my device when I plug it into my computer. None of the LCD sensors seem to be damaged in any way. Please help I don't know what else to troubleshoot.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Sounds like either long screw damage if longer screws were used on the screw holes that were on the logic board for the metal cover that goes over the screen connectors.
The other damage can be no backlight (blown backlight filter usually)
If the screen gets unplugged or plugged in while battery is connected the backlight circuit can go wrong.
Punteggio 6
2 Commenti:
Thanks for the response! How would I test for / solve either of those?
da
Shine the flashlight onto screen and see if you have display. If you see display but dim you have a no backlight issue.
To check long screw damage you would need to inspect the screw holes with an microscope.
da
Aggiungi la tua risposta
graziella sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 764
