Is it the inverter or the inverter cable?
I am attempting to repair a macbook which has recently been dropped from about 2 feet, it was closed, and landed on the display hinge (directly on the casing of the inverter board.)
The Damage (all damage happened immediatly upon dropping): No backlight, though picture is clear as day (with a flashlight)
There is no flickering, the connections were not loose. I don't think it could be a wire but I am not sure, I cannot take out those pink and yellow wires, but I do not SEE any damage.
The computer booted to a hardware test screen when I turned it off and on. For some reason, the computer said that I had a bad hard drive when I ran a hardware test, but I bet that was just because it got knocked loose, it booted fine (besides the backlight) the next time I tried.
I already tore apart the computer and the display, and I do not see any visual damage to the board (though, I do not have much experience with this yet). And there are no severed cables.
I would like to know if there is any way that I can test to see if it is the board or some pinched cable, without having to swap out with this computer's display...
Or, if some professional just knows for sure, and says so, that would be good too.
Thank you for your time.
Update
Update, it isn't the inverter board, I will see if I can borrow a multimeter from a teacher, what cables should I test,
Could Someone provide a picture of where I should place the probes and what setting?
Or maybe just a quick guide?
How would I get to the other side of the pink+white wires, behind the lcd screen?
Questa è una buona domanda?
3 Commenti
Well, it is my mom's computer, and she wants to order the cheapest thing first... so... what wires do I need and where can I get them?
Wires don't cost much, so I would probably buy all of them it could possibly be.
If that doesn't work, I'll change the lcd panel.
It is a Santa Rosa model.
da Ben
Aw man, I just lost 100 and something dollars breaking my keyboard >:(
da Ben
They're not on the other side, it plugs into the bottom of the LCD frame. MacBook Core 2 Duo LCD Panel Replacement
da mayer
