Salta al contenuto principale
The Kenmore 110 Series is an easy to use home Washing machine created by Kenmore.
497 Domande Visualizza tutte
Washer won't spin or agitate
I have a Kenmore Series 100 top load washer. It seems to be having and issue with not spinning or agitating. If I start a load it will fill up with water and then just sit there and do nothing. I can get it to drain the water but it doesn't spin when it drains and doesn't get all of the water out. I was able to put it into diagnostic mode and it gave me four error codes. The first is F7 E6- Motor Fault. Second is F7 E5- Shifter Actuator Fault. Third is F0 E2- Excessive Suds. Fourth error is F1 E1- Main Electronic Control Board. What should I try replacing first? Surely it can't be that the motor, actuator and control board all went bad at the same time?
Questa è una buona domanda?
Punteggio 2
3 Commenti
@geoffj981 what is the exact model number of your washer?
da
Model number is 110.5142510
da
@geoffj981 where do you get a readout on your error code and what diagnsotics test are you running? Does your manual tell you how to clear the error codes and to then run the test again? Any change with your test when you do that? You ran the manual diagnsotics test as well? Did you run the individual tests, like the one for the "Main control"?
da
Aggiungi un commento
3 Risposte
Soluzione Prescelta
If your Kenmore 110 Series Washing Machine refuses to spin or agitate during the wash cycle, see the Kenmore 110 Series Washing Machine Doesn’t Spin or Agitate problem page for possible causes and solutions.
We have too many error codes and need to get a clearer idea. Please unplug it for five minutes then plug it back in and tell us what codes you are getting. Do you have a history of any repairs on this machine?
Punteggio 2
4 Commenti:
I still get the same 4 error codes in the order I listed them previously. The washer is only 1 1/2 years old and I have not had any prior maintenance done on it.
da
I'm over my head on this one. Let's see if we can get some help from a real professional Loretta @ladytech
da
Mine is having the same issue. It is 3 months old probably used less than 30 times.
Not sure I caught how to check error codes
da
@slangest please start a new question and give us your make and model number
da
Well I went with my gut and replaced the lock latch mechanism. That fixed the issue. I guess since it was broken the washer wouldn't do the spin cycle since it was "thinking" the lid was open.
Punteggio 1
the clutch is burnt out...replace it..its easy to do yourself cost around $8-$12 for a new one on ebay
Punteggio 0
6 Commenti:
Would you mind explaining this diagnosis a bit more or provide some support for it?
da
Same exact thing happens to mine, I have sane model.. I replaced the clutch and it runs like new.. YouTube has videos on the repair it's pretty easy.
As long as the rubber coupler isn't broke it's the clutch
da
Before yours went out did you have problems with the lock not unlocking when it was complete? That was the first problem i was noticing. It would wash and spin fine but the lock would get stuck. It made me think the issue is with the lid lock switch going bad and that's why it won't spin.
da
I checked with Sears and they said that my model Kenmore doesn't have a clutch
da
Check again they have a clutch
da
Mostra 1 altro commento
Aggiungi la tua risposta
Geoff Jones sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 17
Ultimi 30 Giorni: 85
Tutti i Tempi: 10,283
