Washer won't spin or agitate
I have a Kenmore Series 100 top load washer. It seems to be having and issue with not spinning or agitating. If I start a load it will fill up with water and then just sit there and do nothing. I can get it to drain the water but it doesn't spin when it drains and doesn't get all of the water out. I was able to put it into diagnostic mode and it gave me four error codes. The first is F7 E6- Motor Fault. Second is F7 E5- Shifter Actuator Fault. Third is F0 E2- Excessive Suds. Fourth error is F1 E1- Main Electronic Control Board. What should I try replacing first? Surely it can't be that the motor, actuator and control board all went bad at the same time?
Questa è una buona domanda?
3 Commenti
@geoffj981 what is the exact model number of your washer?
da oldturkey03
Model number is 110.5142510
da Geoff Jones
@geoffj981 where do you get a readout on your error code and what diagnsotics test are you running? Does your manual tell you how to clear the error codes and to then run the test again? Any change with your test when you do that? You ran the manual diagnsotics test as well? Did you run the individual tests, like the one for the "Main control"?
da oldturkey03
