Salta al contenuto principale
Rilasciato il 19 settembre 2014, è la versione con schermo più grande (5.5") dell'iPhone 6.
1525 Domande Visualizza tutte
Is iPhone 6 NAND storage compatible with iPhone 6 Plus?
Can I replace the storage chip in my iPhone 6 Plus with the one in my iPhone 6? I understand the procedure and know the tools necessary. Are they compatible?
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
3 Risposte
Soluzione Prescelta
They are called NAND.
They are interchangeable between 6 and 6+.
Punteggio 4
@ajrmatt neither the iPhone 6 nor the iPhone 6 Plus have an SSD. (Simplified)All memory is contained on IC's soldered to the logicboard. No, you cannot change it (the SSD).
Punteggio 1
8 Commenti:
It can be changed, and is done frequently with the help of an iPhone NAND reprogrammer, which is what I am planning to do. I am wondering if the two are the same size/format so they can be swapped.
da
SSD? Really? Who and where does it get done frequently?
da
Can be done OT.
da
China. Search YouTube for iPhone NAND Upgrade.
da
@rany Okay that the NAND can but I did not know they used SSD on iPhone's in China. My mistake ;-)
da
Mostra altri 3 commenti
yes--these are interchangeable--of course you have to write the serial number from the old to the new.
Punteggio 0
Aggiungi la tua risposta
Adam sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 1,770
