Salta al contenuto principale
Lanciato a giugno 2012 / processore Core i7 con Turbo Boost / Fino a 1 GB di RAM Video DDR5
596 Domande Visualizza tutte
Showing no sign of life
Hi Guys.
OK never seen this before.
Client brought this in won't start up so first thing to try is battery but it would seem thats not the issue
So i open it up & see if there are any signs of liquid damage ETC disconnected battery connected to power tried to start it up.
None of this worked so i reconnected the battery & connected to power the fans started spinning.
Took it off the battery with just magsafe nothing just connected to battery nothing but when connected to both the fans spin up Mac still doesn't boot.
Before i start searching the issue down as this could be time consuming has anyone come across this before & did you get a resolution?
Yes i'm being cheeky I'm going on holiday on weds so time is tight.
Thank you in advance
Questa è una buona domanda?
Punteggio 0
1 Commento
Hi Reece.
Thank you for your help.
No theres no clicking or i can't hear anything.
I have had some progress I came in this morning it is powering on as the fans spin up either on the power or the battery however if i disconnect the battery then reconnect it does power on & i can log in but it won't when the magsafe is connected but if you reboot it goes back to just the fans spinning up.
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
With the charger plugged in and battery disconnected, listen for clicking on the logic board. I have seen a number of 2012 15" models where they go dead for no reason, and the issue is related to a couple of mosfets on the back of the board. From memory they are related to the 5V DRVL signals.
Otherwise check for liquid damage. Try to ultrasonic it in a good cleaner, could be a small amount of liquid under the SMC causing intermittent issues.
Punteggio 2
Aggiungi la tua risposta
Kenny Leonard sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 366
