Why the car is consuming more fuel
The car showing no other symptoms.but the fuel consumption is double than usual.
Questa è una buona domanda?
A more detailed question should be asked. What type of engine. Is the check engine light on. When is the last time you had a tuneup? My guess is never...
Double the fuel consumption you either have drag (issue with the brake system, seized calipers), sensor(s), fouled plugs, air filter clogged, vacuum leaks, a fuel leak, under inflated tires. Although it won't be a tire issue..
My guess is start with a tuneup, plugs, filter etc..
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 10
Tutti i Tempi: 1,181
