How to transfer data from iPhone to samsung galaxy s8 plus?
I want to transfer data from iphone to samsung galaxy s8 plus?
How should i do?
Questa è una buona domanda?
How should i do?
Hi, Goji, you can use MobileTrans to ransfer data from iPhone to your samsung galaxy S8 plus.
Use Samsung Smart Switch application.
Make a backup of your iPhone using iTunes.
Restore the iPhone backup from iTunes to your Samsung Phone using Samsung Smart Switch.
Great app but I don't believe you can download the Smart Switch app on the Apple App Store.
You need to create an iTunes backup on iTunes with the iPhone connected.
Smart switch on the computer will check for previously created iTunes backups and will let you restore the data back onto a Samsung phone.
if you want to transfer contact than you can do it with icloud. just export icloud contact to computer and then import that contact to samsung mobile. for that open icloud then click on contact then at bottom you will find import export contact option.
or take backup on itune then use samsung smart switch to transfer data from iphone to samsung mobile via itune backup.
So, if you are having any troubles to transfer iPhone data to Samsung phone then simply follow this guide where we will show few ways to transfer data from iPhone to Samsung Galaxy S8,including contacts, text messages, photos, videos, call logs and music, as well as iPhone to Samsung S9/S8/S7/6/Note 8.
Once you lost data on Samsung, you can learn this video guide to recover deleted data from Galaxy S9/S8:
I guess you need a phone transfer to transfer files from iPhone to Galaxy S8. This tool allows you to transfer videos, contacts, photos, and more files easily
Samsung Transfer is designed for Samsung and iPhone. With it,you can transfer lossless files between two mobile phones.
It can move contacts, messages, call logs, photos, music, videos and apps, to Samsung easily. The user-friendly interface, on which display all the file catalogue, allows you to select data intuitively.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 1,966
