http://repair4laptop.org/disassembly_tos... has a bunch of instructions I did notice that the LCD replacement for the A135 is not specific but there are plenty of others that will get you there.
Little bit more information that you can use for your task
Instructions
Shut down your Toshiba laptop. Close the display panel, and disconnect the AC power supply cable. Place the computer with the top side facing downward on a flat surface. Position the computer with the front edge facing toward you.
2
Slide the battery release lever to the left. Then remove the battery pack from its compartment along the top edge of the laptop's bottom side.
3
Flip the laptop over, and open the display panel as far as possible. Use a small, flat-head screwdriver to pry the rubber screw covers from the display panel's front bezel. This is the main plastic cover on the front side of the LCD screen.
4
Remove the Phillips-head screws fastening the front bezel to the display panel assembly. Remove the front bezel. This may require a thin tool like a flat-head screwdriver or guitar pick to pry the front bezel from the LCD screen.
5
Remove the Phillips-head screws from each side of the screen. Grasp the top edge of the screen, and tilt it forward. Disconnect the large LCD ribbon cable from its connector on the back of the screen. Peel away the adhesive tape securing the cable to the back of the screen.
6
Locate the inverter board on the back side of the screen. Disconnect the cables on each end of the inverter board. Remove the Phillips-head screws securing the inverter in place. Remove the inverter from the screen.
7
Lift the entire LCD screen out of the display panel. Locate the white, plastic piece lining the top edge of the screen. This plastic piece houses the backlight lamp. Grasp the piece and lift it off the screen.
8
Remove the backlight lamp from the plastic housing. Use a soldering iron to disconnect the wire connectors from each end of the backlight lamp. Throw the old backlight away.
9
Reverse this procedure to install the new backlight. Before installing, you will have to use the soldering iron and some solder to reconnect the wire connectors to the new backlight and then reassemble the laptop.
Read more: How to Repair the Back Light on a Toshiba Satellite A135 | eHow.com http://www.ehow.com/how_7412102_repair-l...
and here is a bunch more info. http://www.screentekinc.com/lcd-removal-...
Good Luck to you
Votato
Annulla
Punteggio
Annulla
Scorri questo thread per trovare il posto appropriato per questo commento. Quindi, fai clic su "Allega commento a questo post" per spostarlo.
