First aid found couruption that needs to be repaired
How do I fix the courption ????
Thank You
Questa è una buona domanda?
Thank You
Generally, You need to boot up under an external boot drive so you can run Disk Utility from it. This can be a USB, FireWire or Thunderbolt drive (depending on your exact model); or use a second Mac using Use target disk mode to share files between two Mac computers
While that can address minor issues, you may have a deeper hardware issue here. Like a bad drive and/or a bad HD SATA cable. But this depends on your exact model what is needed here.
This worked thank you
The computer always acted fine just that message was annoying lol
Try booting into recovery by shutting down the computer and holding [command+R] during startup. Then repair the disk though Disk Utility.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 169
2 Commenti
The image you posted shows some distortion is that what your screen looks like. If it is I think you have deeper problems here ;-{
Can you give us the exact model you have as Apple has quite a few different versions! Paste in your systems S/N here EveryMac - Lookup, then post the system URL link here for us to see.
da Dan
Mid 2012 13 inch pro with Samsung ssd 500gb the screen looks like that because I took a picture of it with my phone
da Collin.nesbitt@gmail.com
