Salta al contenuto principale
Latch won't open after installing new harddrive
I upgraded my harddrive and installed OS without a problem, but after putting the case back together, the latch won't open fully, meaning I need to use the spludger to gently pop it open. I had a similar problem when I had my RAM upgraded last year, but the guys at the shop where I had it done were able to fix it. I'd prefer to not have to go back there again.
Does anyone know how to fix this?
Questa è una buona domanda?
Punteggio -1
1 Commento
thanks for your help guys.....not sure what the problem was but it worked itself out....I think it was just an alignment issue
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Most likely is that the top case was improperly aligned improperly. It's impossible for us to tell over the internet. I would examine how it's binding and reseat the top case.
Punteggio 2
Hi, it sounds like there may be a small screw lodged somewhere underneath or behind the push-button bar. I think you can remove that bar after you've removed the top cover. From there you can see if there is anything keeping that press bar from being fully depress.
Punteggio 0
1 Commento:
charles, I don't mean to be tacky but do you really think he's still having this problem after seven months?
da
Aggiungi la tua risposta
stevehort sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 1,107
