speakers won't put out any sound
Why does it display Headphones on screen when I try to adjust volume and no sound comes from speaker?
Questa è una buona domanda?
Get a pin or something like that and give the headphone jack a good clean out.
They gather fluff up there and it could be causing the problem.
If that doesn't work then it would need replacing.
Not a massive job so it should be a cheap repair at a local shop if you aren't confident enough to do it.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 34
Are you referring to the built in speaker or did you connect an external speaker to the iphone? Then headphone icon would indicate your have a plug in the headphone connector - but what is connected? Is it a powered speaker, does it have a volume control? Does the phone normally work as a phone?
da Spikey2
